Symptoms of rear drive shaft support failure
Old Nov 18, 2021 | 07:56 AM
mawRover's Avatar
Originally Posted by kenneypj1
It been too long to remember the exact sound. I think I got a more metallic “ping” with the roar on the rear diff. Have you compared the two diffs with the transmission housing and transfer case housing?
I have listened to the TC it sounded fine. Have not tried transmission yet. Just changed front wheel bearings and listened to the rears and they sounded fine.
Old Dec 16, 2022 | 10:27 AM
P-Bod's Avatar
Originally Posted by mawRover
I took some video of the sounds: https://youtu.be/7SwCCLD3FSc. Do any of those sound like yours??
I attached the leads to the bolts on either diff housing and for the sides of the diffs just clipped them to whatever surface was closest to the side bearings.
My drivetrain sounds just like yours, without the chassis ears. It's nice how that really amplifies and pinpoints the noise. Did you ever rebuild/replace either front or rear diff?
Old Dec 18, 2022 | 02:57 PM
mawRover's Avatar
I haven't done anything yet. Probably only put on 5k miles since then. Are you planning on doing anything to yours?
Old Dec 19, 2022 | 08:34 AM
P-Bod's Avatar
I don't plan on doing anything unless the noise gets much louder. I will check and likely replace the fluid in front/rear diffs, transfer case, and transmission. The previous owner did all of the above, but I'll verify it for my own peace of mind. The previous owner did do the transmission metal pan swap, but I'm pretty sure he didn't re-seal the valve body. So, I'll do that and verify the fill level.
My new 2006 sounds a lot like my 2007. I'm trying to decide if these rigs just have a somewhat loud drivetrain. I believe I am hearing the load on the ring gear (front or rear diff) while accelerating or decelerating. By feathering the throttle, you can hear the transition from pull to drag. If it was a bearing, the noise would be there full time while rolling.
Or, I'm crazy and just turn the radio up. So far the wife nor any passengers have ever said, "what's that noise?" If that happens, I might need to dig deeper.
Old Dec 19, 2022 | 08:47 AM
mawRover's Avatar
I'm in the same camp. The PO of mine told me when I was test driving it: "you can hear the gears on these cars", and that's kind of stuck with me. Honestly I just use those words as hopium as I pray for it not to get louder lol.
Sounds like you have some experience here! Please post back if you ever find a fix, and I will do the same.
Old Feb 4, 2023 | 08:28 AM
P-Bod's Avatar
Default Suspension Day
Since my last post I have changed front and rear diff and transfer case fluid. No change in any of the noise.
Doing suspension work today, I can fully isolate the wheel bearing, and it’s kind of loud!
Old Feb 4, 2023 | 08:36 AM
mawRover's Avatar
https://youtu.be/7AzLHTcxi9M
That sounds a lot like the noise! I changed my front bearings and didn't notice any difference, but didn't do anything to the rears.
Old Feb 5, 2023 | 10:47 AM
DakotaTravler's Avatar
Rears are not exactly fun to change. The typical average life of the rear bearings seem to be about 150k miles - obviously there is some give or take in that milage. I think mine made it to 175k? I know some that have gone past 200k. But I also know some that failed at 125k.
Old Mar 6, 2023 | 04:31 PM
P-Bod's Avatar
New front Timken bearing/hub assemblies didn't do much to quiet the drivetrain for me either. Maybe a smidge, but that's probably just me justifying the parts cost! Probably needs a differential.
Old Mar 8, 2023 | 11:45 AM
mawRover's Avatar
Dang, well it was worth a shot though. Here's hoping mine gives me ample notice before it fails
The_OGCJR
Dec 5, 2021 08:11 AM
hrhoward
Aug 24, 2016 11:15 AM
windsoreight
Jul 15, 2014 06:37 PM
hatanhi
Jul 23, 2012 06:46 AM
bonzadesign
Dec 25, 2010 11:35 AM
