T Case output Bearing
Old 03-22-2017, 10:12 PM
GBR.R's Avatar
Default T Case output Bearing
Hi apparently I have a noisey front T Case bearing,thought it was my Front Diff but that was Changed About 8000 miles ago. Does anyone know if this is a T Case out bearing rebuild job or is it as the mech who looked at it said drive it till it breaks as not worth doing, then drop in a New / rebuilt T Case.
Old 03-24-2017, 10:39 PM
GBR.R's Avatar
ok so it's a replacement T Case as the only option, seems no one bothers to fix these.
Old 03-24-2017, 11:38 PM
abran's Avatar
I think I saw you posted in the D2 section as well.
are we talking D2 or LR3?
Old 03-25-2017, 09:41 AM
abran's Avatar
I am going to embark upon an LR3 transfer case rebuild soon. Unfortunately I have not found any information on it yet. When I do I will be sharing.
Old 03-25-2017, 10:08 PM
GBR.R's Avatar
Hi did not post in D2 section at all, yes we are talking LR3
Old 03-25-2017, 10:40 PM
cmb6s's Avatar
@abran, this is a fantastic thread on the dd295 tear down and rebuild. I bookmarked it long ago, but haven't found one cheap enough to buy and fiddle around with yet. Hope it helps.
Magna Steyr DD295 Transfer Box Teardown
GBR.R (03-26-2017)
Old 03-25-2017, 11:33 PM
abran's Avatar
sorry, I thought I saw it posted somewhere else. Must be the Chimay talking
GBR.R (03-26-2017)
abran's Avatar
stoked!
Im on it. Thank you
Old 03-25-2017, 11:45 PM
abran's Avatar
ok, it was partially the fault of drinking Chimay... I saw you responded to a D2 thread.
Old 04-14-2017, 12:40 AM
hell pie's Avatar
I replaced all three seals on my transfer case a few years ago. You'll need a chimpanzee to help you remove some of the bolts that attach the transfer case to the transmission. Why a chimpanzee? Because they have smaller hands to access those IMPOSSIBLY tight spaces, and they have incredible animal strength to break the bolts free. You'll also need a stubby ratcheting wrench because again the clearance is insanely minimal. Lastly you'll need patience, lots of it, because you'll only be able to make 1/100 of a complete turn with your wrench due to the tight space.
GBR.R (04-18-2017)
Quick Reply: T Case output Bearing
