Temp sensor issue or air bubble or head gaskets!
Old Dec 21, 2022 | 12:27 PM
houm_wa's Avatar
Originally Posted by Blackngold77
If it is air, I'd recommend burping the system the next time the temp spikes. For all the bleeding I've done on these they almost never get rid of all the air.
Next time it spikes, pop the hood and unscrew the coolant cap. That will let out any air. Top off the coolant and you're good to go. You may have to burp it a couple times.
You can test the thermostat on your stove. Boil some water and put the thermostat in it, if it's working it will pop open. If not, you need a new one
Do I pop the hood and unscrew the coolant cap (on the expansion tank I assume) while the engine is running? Or shut it off first?
Old Dec 21, 2022 | 01:17 PM
Blackngold77's Avatar
Yup, unscrew the expansion tank cap. You can do it with the engine on or off. The time I did it because the temp spiked in the red I shut the engine off then unscrewed the cap. If it needed to be burped, you should see some air gurgle out and the level drop down.
Just unscrew it slowly, it shouldn't spit coolant at you but that's always a potential on a hot engine.
Old Dec 21, 2022 | 04:13 PM
houm_wa's Avatar
One more thing to add, sort of a biggie I don't know why I neglected this:
My Climate Control blows cold even when selected fully to hot. Does that indicate an air pocket still or a thermostat?
Old Dec 21, 2022 | 06:17 PM
P-Bod's Avatar
You’re heater core is probably dry, meaning low coolant. The hoses to and from your heater core should be warm/hot.
Old Dec 24, 2022 | 08:58 PM
houm_wa's Avatar
Default Update
I changed the thermostat today. Drove it....temp gauge spiked again. I pulled over and opened the expansion tank cap and let air out until coolant bubbled over. Drove it more and I have had no issues since. A couple times I stopped to let more air out and top off the coolant, which seems more stable now. I have put 20 miles on it... victory?
Oh, the heat works again too.
Old Dec 24, 2022 | 09:08 PM
I changed the thermostat today. Drove it....temp gauge spiked again. I pulled over and opened the expansion tank cap and let air out until coolant bubbled over. Drive it more and I have had no issues since. A couple times I stopped to let more air out and top off the coolant, which seems more stable now. I have put 20 miles on it... victory?
Sweet, glad to hear you got it happy again. I think it should be fully burped now if its holding temp and blowing heat.
Just give your reservoir a check next time you go to drive it to make sure the level doesnt need 1 last top off.
back9sunday
Aug 8, 2016 10:43 AM
GamecockRover
Oct 30, 2012 05:29 PM
nik
Jun 3, 2012 10:06 PM
willlane
Jan 4, 2008 09:05 AM
