Tire Size Change
Old Jun 10, 2010 | 01:18 PM
mac308's Avatar
Default Tire Size Change
Hello,
I just changed my tires from size 255/60R18 to 285/60R18. Shortly after the change I noticed that my 2006 LR3's suspension will not go to the low setting but it will still rise. Has anyone else had the same issue or do you think the issue is not related to the tire size change. I haven't lifted or lowered the suspension for a few months but the last time I did it worked fine.
Thanks,
Chris
Old Jun 22, 2010 | 12:50 PM
dmccoig's Avatar
Those seem to be be pretty large tires for stock height. Do you have any lift on it? Just theorizing here, but you may have some interference somewhere.
Old Jun 24, 2010 | 12:46 PM
Sully's Avatar
4wd High
I too have an '06 and upgraded my tires to 285/60R18's but don't have a problem going into Access mode. My assumption is that if you were attempting to lower the vehicle and it encountered a hard stop somewhere, it will then go to super-extended mode.
Anything show up in the command center on the dash when trying to put it in Access mode? I wonder if you need to take it somewhere to see if you have any fault codes.
Old Jan 7, 2011 | 07:18 AM
disco_lr3's Avatar
5th Gear
I got a used 06 LR3 that came with 285/60R18, no lift. No problem so far.
Old Jan 15, 2011 | 09:55 AM
jimbiram's Avatar
It may be your switch. The only issues that I know of with that tire is the left front tire height sensor wiring that needs to be relocated due to tire width. I picked up a fault and had to rewire that wiring. Also, there will be minor wear in front of rear wheel well. It doesn't sound like a tire related issue, though.
Notenuff
Jan 21, 2014 08:42 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
