Tire Upsize 2005 LR3
Old Sep 15, 2023 | 03:35 PM
!LR3Rocks111's Avatar
Default Tire Upsize 2005 LR3
What's best upsize tire for year round use? New to site 2005 LR3
Old Sep 15, 2023 | 03:55 PM
JRev's Avatar
I just went through this haha. www.johnsonrods.com will give you all the info you need on that.
I'm about to do the 2.5 lift with 255/65/19 (32's) tires, which is the biggest you can really go with my stock 19 rims.
Old Sep 16, 2023 | 12:28 PM
douglastic's Avatar
Best? or Biggest?
I could argue that 265/60R18 is the "best" because:
- there are many more tire choices in 18s than 19s
- you have a bit more sidewall than stock
- the spare still fits in the stock location
- your MPG will not suffer
- you will not rub, or be immobilized on bump stops if your bags fail
Old Sep 17, 2023 | 07:57 PM
loanrangie's Avatar
Agree with Doug, 265/60/18 is the ideal alround size for a stock vehicle. If you plan to carry a portable compressor then 265/65/18 would be the next choice, if you are happy to fit a wheel carrier of carry the spare on the roof or in the rear then 275/65/18 would be the biggest without doing any mods. You'll still want a lift be it electronic or via rods, get a GAP tool and that will allow you to alter the heights and read/clear codes and edit the vehicle's CCF.
Old Sep 18, 2023 | 01:42 PM
P-Bod's Avatar
I have a 265/65/18 fitted in the standard undermount spare compartment however, the plastic exhaust valence (or whatever that is) is completely removed and the spare is deflated in order to fit. I have a cheap 12v electric air pump in the back.
Capitalman1
Feb 25, 2022 11:19 AM
05lr3guy
Apr 4, 2012 04:22 PM
brianbs
Oct 11, 2010 01:54 PM
bellaroxio
Aug 30, 2009 08:02 PM
Kevs LR3
Aug 18, 2008 09:15 PM
