Tires for LR3
Old Apr 22, 2011 | 06:48 PM
Southern Edge's Avatar
4wd High
Just posted a few pics in the photo gallery under BFG AT's
Old Apr 22, 2011 | 06:50 PM
4wd High
https://landroverforums.com/forum/me...-sexy-2576.jpg
Last edited by Southern Edge; Apr 22, 2011 at 06:53 PM. Reason: how do I get the pic to post here?
Old Apr 22, 2011 | 07:23 PM
unseenone's Avatar
Choice 1
Nitto Terra Grappler LT285/60R18 E125R Part # 200-880 31.5" diameter
tread depth 15.6 32nds
Choice 2
Nitto Terra Grappler LT285/60R18 E120S Part # 200-410 31.38" diameter
tread depth 13.6 32nds
I've run 2 sets of #2 and 1 set of #1, good stuff.
Bigger Tires-- move this wire Bigger Tires? Move this Wire! | Land Rover LR3 Tips & Info
Will Bigger Tires Rub Will Bigger Tires Rub? | Land Rover LR3 Tips & Info
for LR3/DIII/RRS Differential Rebuilt Kits pm me, name, address, e-mail, phone. Gallery: DISCO3.CO.UK Photo Gallery - Home > Member Galleries > tlt
Old Apr 30, 2011 | 06:27 PM
Johnson Rods's Avatar
LR Forum Vendor
I believe the Good Year Silent Armor is the best AT tire. It quiet, has excellent grip for off road and the kevlar side wall prevents pinch flats and adds stability when the tires are aired down. Tire size chart:http://johnsonrods.com also, check out our roof racks page.
Old Jun 26, 2011 | 08:43 AM
Hokie Rover's Avatar
4th Gear
My Conti Cross (265 55 R18) are about worn out on my 08 LR3. I was wanting something a little more aggressive to go off road with. What's a good off road tire that's not loud?
Old Sep 23, 2017 | 06:26 PM
plumnellemoon's Avatar
Default 265/65/18
Originally Posted by simpson lr3
i just put on some hankook tires 265/65/18 they dont rub or any thing they are great!!!!
Do they rub when in lowest setting? Do you have a picture?
Old Sep 26, 2017 | 08:17 PM
jwalk1995's Avatar
Installed 275/65/18 Ko2s a few weeks back and love the ride. I had Cooper Discovery's 265/60/18 before the switch. They made some mods for me. I've attached pics of the work. Maybe they'll help someone. I'll be taking it out for the first time this weekend to the Hill Country Rover Rally. I'm a newbie to offroading anything so this will be a first for me.
Standard Height with a little slant in the driveway.
Old Sep 26, 2017 | 08:36 PM
abran's Avatar
I have cooper zeon 285/60R18. No rubbing in access height full lock left and right.
07' and newer have a different fender well trim and the fronts need to be" tacked" down to the frame(usually just the driver side), the plastic sticks out a little further, but it bends back and can be held by a self tapping screw.
Old Sep 12, 2020 | 06:19 PM
RoverTony's Avatar
Hi! I have 19s with Duratracs in stock size which came with my LR3 when I bought it. I’m debating the move to 18s and 32” tires, 275/65/18, as the replacement.
I’ve been researching tires. I believe I’ve decided on either the BFG AT KO2 or on Duratracs. Most of the threads I’ve come across in the LR forums for tires are several years old so I’m curious of owner experiences with their tires since in various conditions.
Most of my on road use is highway and my most frequent off road destination is the beach. I also head up to the mountains as much as I can in the winter too. I do intend to do more dirt roads, forest trails but nothing with severe mud nor sharp rocks to warrant an MT tire. I do not want to switch tires each season to a dedicated snow tire. The Duratracs have been fine in the snow that I’ve experienced thus far in the few years of running these tires and at 16-18 psi they do great in fine soft sand, with DSC off I don’t even switch into sand mode... they perform wonderfully. The Duratracs are somewhat noisy on the highway, more so now that they are worn (a couple tires are starting to cup). MPG even loaded down with voyager rack, rack lights, and running 40 psi is still really good in the 19-20 mpg range at 65-70 mph.
When I picked up this LR3 a few years ago I was convinced of going to the KO2, but the Duratracs have impressed me and have an aggressive look. Is there much more performance benefit in a different tire than Duratracs to justify the move?
Old Sep 12, 2020 | 07:48 PM
adamw412's Avatar
