TPS Sensor Replacement Options
Hello - I was wondering if someone could tell me the options of replacing the TPS sensor. Last year, around this time (outside temp here is 15 degrees) the inside of the stem blew out. Same happen again yesterday (different tire). I was wanting to avoid paying the dealer $130 for a sensor, if I could find a aftermarket sensor that would work the same. Also - as fyi... not sure about other years but the dealer wanted $75 to install the sensor and $50 to program. The sensor does not need programming. My local tire shop installed sensor for $20 and all was good.
Well it seems your local tire shop is a good option at $20! Why not use them again?
You can get the IIDTool and just turn the TPMS off altogether, that is another option.
Otherwise, eBay has sensors as well.
MoShadeTree (01-06-2015)
BloodyShirt
03-25-2015 12:08 PM
