Transmission “fixed” but now I’ve lost sport and manual mode
#31
I had accidentally bent a pin on the mechatronic TCM when re-installing everything. New (used) part fixed the issue.
if you haven’t recently unplugged your mechatronic unit, then it is more than likely an issue with corrosion on the shifter assembly connector or the TCM under the hood.
#32
#33
Where is the mechatronic located? I've unplugged the connector on the shifter assembly and it looks clean. TCM?? is that the Transfer case control module or is that referring to something else? I've already replaced the TCCM and got a lot of stuff resolved. The "D" on my selector stays lit 24/7.
the mechatronic unit is inside of the transmission itself. You have to remove the pan to get to it.
the mechatronic unit will almost certainly have nothing to do with what lights up on your shift column.
#34
okay, so I did replace my transmission filter with the AB conversion kit, but I didn't mess with the mechatronics or anything else in there. Yeah, my selector "D" stays lit and my sport mode does not work. My dash works from PND, but once I move the gear selector over to sport mode for manual shifting it still shows D. No error messages, no OBDII codes. It drives great, but I'd like for it to work for when I go off-road or want to manually downshift to pass. I bought a new gear selector assy, I may swap it out and see if that does anything.
#35
#36
I don't think I get anything. I've moved it to the left, I don't remember seeing any little "sport" next to the D. I've tried to run through the gears and I don't get any numbers. Gotta be an electrical connection somewhere. I don't believe the linkage down at the transmission does anything with command shift, it just controls P-R-N-D. Command shift is electronically controlled.
#38
#40
Its electrical. You need to check the TCM under the hood (behind the battery) and physically remove the shifter and inspect the connections.
