Transmission fault
many things can be wrong at this point, does it crank over or it doesnt even do that? let me list you the quick things you can look at. possible fluid spill by the shifter and corrodes the shifter connector. possible battery leak/explosion caused tbox module to short or water damage. those are the most commen areas i have ran into
The alarm has been going off just about everytime you lock the doors and walk away. Also lights sometimes blink numerous times when I lock the doors. I am thinking maybe it just needs a new battery. Maybe losing connection or something. The car fired up this morning with no problems, but all these things seem to be happening quite often. Don't really have a clue.
And yes Geaux TIGERS!!!!'
kbarker27
10-13-2023 04:03 PM
Arth111
02-26-2022 06:28 AM
06Range
05-08-2013 09:01 PM
