Transmission fluid
Old Oct 12, 2022 | 04:51 AM
spinach_e's Avatar
Default Transmission fluid
Hey guys
i recently did the transmission pan conversion with the kit and full batch of ZF Lifeguard Fluid from Atlantic British. On first go, the included paper gasket was leaky. So, on second go, I got the Fel-Pro tos18753 and added some more ZF for to replace the lost fluid.
But, I didn’t have enough ZF to top off the transmission. My mechanic says I’m about half a quart low. Ordering more ZF will take a few weeks. Are there any (readily available) alternatives to ZF that I can use to mix with the ZF? I think I read somewhere on this forum that you can combine ZF with other trans fluids. I’d rather not but I’d hate to drive around with a half quart low on trans fluid for 3 weeks.
Old Oct 12, 2022 | 08:41 AM
kajtzu's Avatar
Ideally you shouldn’t mix two different fluids but add like for like.
As far as I know Shell M-1375.4 is identical with ZF LG6. Similarly Mercon SP is supposed to be identical with Shell M-1375.4. The latter has been used in Ford 6R80 transmissions, that are licensed from ZF 6HP transmissions.
Not the most ideal answer, I know.
Old Oct 12, 2022 | 08:47 AM
kajtzu's Avatar
To add to this, you can get ZF LG6 from Amazon, for some price per bottle, overnight (checked destination Palo Alto, CA) if you absolutely need it.
Old Oct 13, 2022 | 06:04 AM
spinach_e's Avatar
i’m not in the states. It’s a bit harder to get stuff here. But I just checked Amazon and amazingly ZF LG6 does ship here. That’s kind of amazing. Thanks for the rec!
djkronik57
Oct 29, 2021 11:00 PM
Athana
Jun 8, 2019 10:23 AM
gfly66
Mar 22, 2017 10:13 PM
Roverrrgirl
Dec 8, 2016 04:51 PM
Jupe209
Aug 29, 2010 11:29 AM
