Ugh. Still an issue with the passenger seat
Old Jul 25, 2019 | 10:27 PM
Philip Chan's Avatar
Default Ugh. Still an issue with the passenger seat
I had this error -
B00C0-96 (AC) Passenger's seat occupant classification sensor A - Component failure - internal failure
I replaced the Right Front Seat SRS Module YWC500035 to no avail. Reset the codes. It's fine for a few minutes, then it repeats the code.
I noticed, after reset, when I press with medium weight on the seat, the "airbag off light" comes on - which it should because medium weight in the seat (ie. the airbag is not supposed to explode).
I can do this a couple of times, then it trips the fault again.
Does this mean it's the actual air bladder that's the issue? or is there anything I can check to see or fix before replacing this?
Old Jul 26, 2019 | 05:17 AM
Globetrotter448's Avatar
Have you checked the plug and wiring
Old Jul 26, 2019 | 01:33 PM
Solved!
Please take note of this -
I tested everything! Plugs, wires, continuity.
It was the belt connection (where it attaches to the seat. It has to be screwed in all the way - I guess it needs to ground the system for it work (like most things on these bloody vehicles!).
There are prongs that need to be fully compressed and connected to the seat to work.
WORKS NOW!
Will report if this plays up again.
Philip Chan
May 11, 2019 10:44 PM
Armando
Nov 4, 2017 09:58 PM
DiscoBuckeye
Jun 12, 2016 08:29 AM
Xrover
Apr 9, 2012 11:25 PM
rover2003
Nov 7, 2007 09:53 AM
