Bunch of fault codes from passenger seat - airbag light is on.
Old May 11, 2019 | 09:11 PM
Philip Chan's Avatar
Default Bunch of fault codes from passenger seat - airbag light is on.
So thanks to my handy Gap tool, I see a bunch of codes on that pertain to the passenger seat/airbag.
Now, I did have this seat out, to deal with the damp floor and the reconnect the remote wiring joint which had rotted away.
I plugged back in seat and it's now throwing errors. This amongst others.
B00C0-96 - Passengers seat occupant classification sensor A - component failure - internal failure.
I've looked at every connector on the underside, including the main black box that connects the loom to the seat. I can't seem to find an issues.
Could I have damaged something in taking it out?
And if so, wouldn't it just be cheaper for me to source a good used seat to put back in?
Old May 11, 2019 | 10:06 PM
DakotaTravler's Avatar
Just clear the code. If you had the seat out and powered up the vehicle for any reason you will get a code even when everything is hooked back up. SRS systems dont play around when it comes to faults, most SRS codes are hard faults that will stay until cleared.
Old May 11, 2019 | 10:38 PM
Actually, forgot to add - cleared them. Then they came back.
Old May 11, 2019 | 10:44 PM
I cant say for sure what that code means, but the seat belt buckle has its own sensor and connector underneath. I sorta doubt you damaged anything, I would bet on it being something not plugged in fully. I wold disconnect/reconnect a few things. Or at least try to pull the connectors apart to be certain they are secure.
Philip Chan
Jul 26, 2019 01:33 PM
Armando
Nov 4, 2017 09:58 PM
lr3_ovrlnd3r
Apr 10, 2016 09:12 PM
Pbpuckett
LR2
Feb 5, 2014 09:07 PM
Xrover
Apr 9, 2012 11:25 PM
