Uh oh. I think I messed up :(
Old Jul 8, 2019 | 05:55 PM
Oceanguy33's Avatar
Default Uh oh. I think I messed up :(
I replaced the fluid in my rear diff. But I think I replaced it through the wrong opening.
I have HD package and refilled through the long hex bolt not the rear of the diff. I’ve driven a bit on it too.
What at is the bolt and what have I done here? And where is the fluid? 🤬
I know now if probably should have filled up here instead :
So. What can I do? I think I majorly messed up here.
Old Jul 8, 2019 | 07:14 PM
abran's Avatar
The only problem I can see is that you might have under/overfilled as its fill to spill on the actual fill plug. I don't remember seeing the plug you filled, but I get so used to seeing things sometimes an obvious thing I miss.
Old Jul 8, 2019 | 07:39 PM
Oceanguy33's Avatar
Thanks abran.
I filled it via the first picture plug. I later found this was not a plug but more of a bolt. Then I found that this helps set the differential in some way . Have I messed up my diff?
Also. This is strange but I thought these e-diffs have a long hex bolt that sticks out far from the diff? Mine was just this....
Old Jul 8, 2019 | 07:40 PM
abran's Avatar
Ok, here is one I rebuilt off an 05’
here is a new genuine we have on the shelf with 2012 date code:
Old Jul 8, 2019 | 07:41 PM
abran's Avatar
go back and refill from the proper hole until a small stream comes out and close the fill plug. you should be fine.
Old Jul 8, 2019 | 07:43 PM
Oceanguy33's Avatar
Thanks. I take it this means drain and refill using the same just into a different hole....
and what of the bolt? What have I done now I’ve removed and replaced it?
Does it it set the clutch or something up?
Old Jul 8, 2019 | 07:57 PM
abran's Avatar
So there was a bolt like in my first photo and you remove that and replaced with a drain plug?
Old Jul 8, 2019 | 07:59 PM
abran's Avatar
Also, no do not drain just still to the point to where it’s at the right level.
If memory serves me that bolt is just a stop for one of the assemblies that turns inside the case
Old Jul 8, 2019 | 08:01 PM
Oceanguy33's Avatar
No no. The plug I removed (which had a long bolt on the back side of it) was like your 2012 example.
I did did not have the hex type protruding bolt at all.
Old Jul 8, 2019 | 08:02 PM
abran's Avatar
OK, I think you are good just make sure that the level is proper
