Using the remote to adjust suspension height
Old May 6, 2010 | 01:49 PM
soap2yadome's Avatar
Default Using the remote to adjust suspension height
Has anyone programmed their remote to do this? I've been trying to follow the instructions in the manual, but I just haven't been able to make it work. Just wondering if anyone has tricks/tips... Thanks!
Old May 6, 2010 | 07:00 PM
chkg0721's Avatar
4th Gear
I'm not sure if you have tried yet, but if I remember correctly you must have the emergency flashers on and all doors closed to make it work.
Old May 6, 2010 | 08:45 PM
trynian's Avatar
Yes I have, but it is not really useful. As the other poster mentioned, once the key is programmed you have to unlock the car turn the flashers on then close the door for it to work.
By then I could have already put the key in and done the same thing.
I find that programming the third button to turn the lights on is more useful.
Old May 7, 2010 | 12:33 PM
Thanks for the tips, I just went and tried again and got it to work!
I saw a LR promo video showing the remote being used to lift the vehicle while hitching to a trailer. I just figured I'd give it a try and see if it's useful... I can see myself going back to having it turn the lights on.
Also, an FYI- I installed an aftermarket hitch last night... while it was not as easy as connecting the LR hitch, the $225 savings made it worth-while for a DIYer.
Old May 8, 2010 | 02:43 AM
accpac1's Avatar
Default your comments about a hitch
Hey - first post here and finding the content very good. I am looking at an LR3 Se(V8 model) and I want to use it as a tow vehicle for my boat. What is the price of the factory hitch vs the aftermarket? I am not a DYIer, so could you comment on what specifically was difficult about the aftermarket install. I have been told that all these vehicles are equipped with the wiring for a trailer - is this true?
Old May 10, 2010 | 02:18 PM
Sully's Avatar
4wd High
Has anyone programmed their remote to open the upper rear tailgate? Mine sounds like it unlocks and moves slightly but never really releases to the point that it frees itself from the latch to raise completely. I have to open it manually at that point.
Old May 10, 2010 | 08:32 PM
roverguy7's Avatar
sully, thats kind of how it works, it hits 'unlatch' and then relatches, and if youre lifting it when you hit that it goes all the way up, if not, it just halfway does it because it isnt moved out of the way of the latch. the same thing happens if you just hit the release switch and dont lift up
Old May 11, 2010 | 01:01 PM
Sully's Avatar
4wd High
Thanks Dave. It doesn't seem like much of a benefit so I will re-program the remote to work the suspension.
Thanks again.
00Balls
Nov 7, 2012 07:29 PM
derohanes
May 18, 2012 03:26 PM
DiscoIIBrandon
Mar 24, 2012 10:37 PM
RROJ
Oct 9, 2010 07:39 AM
RROJ
Oct 8, 2010 09:56 PM
