Voice Control System Beeps
Old Mar 18, 2009 | 05:56 PM
kasapearson's Avatar
Default Voice Control System Beeps
My new 2008 LR3 seems to have a bug in the Voice Control System. At times it works properly, but it often responds with a constant, high-pitched tone. For example, when I press the switch on the steering wheel, it is supposed to respond with a short tone and then wait for me to provide a spoken command. However, instead of a short tone, it often responds with a continuous high-pitched tone (ear-piercing, actually) and this tone continues until I press the switch again to cancel the voice input. It will continue to do this every time I try to use the system, until the car has been turned off for several hours. If I turn the car off for a short period (even for a couple hours) and then try again, the problem persists. But usually if it has been off overnight, then it will have a chance of working properly the next day (maybe). Any similar experiences? Do I need to tell the dealer to replace the whole module?
Old Mar 18, 2009 | 09:56 PM
roverguy7's Avatar
generally you would tell the dealer to diagnose the problem, exspecially when you dont know what module you would want them to replace... do you have factory or acsessory fit bluetooth? if youre not sure, look at the rh side of the steering wheel, where the phone buttons are, on the very edge of those buttons can you see where it look like someone cut out a portion of the plastic for those buttons?
JC Kotze
May 30, 2015 03:01 AM
PEPEPEPE
Sep 17, 2012 02:38 PM
LR3 Lover
Feb 17, 2009 03:20 PM
meltdowndave
Apr 21, 2008 07:39 PM
Scooby Doo
Sep 4, 2007 11:43 AM
