Voltage Woes...
Voltage Woes...
Ok so I just got my rover a few months ago and have been working on slowly transforming it into an overlanding rig. So one of my first buys was a proud rhino power panel. Now my issue is that the voltage stares me in the face all day long! So I know there is a problem because it will read 14.4 when I start it in the morning and as the truck warms up the voltage starts dropping, sometimes as low as 13.2.
So here is what I know so far, the battery is good! Voltage is 12.4 with the engine off. I unfortunately had to the replace the alternator because the other one went bad, so I have a certified remanufactured bosch alternator that I got from Rock Auto that's been in it a month.
What am I missing? Has this happened to anyone else?
Thank you in advance!
Seems pretty normal to me. The alternator is regulated like most are, the only exception is on the LR3 the computer had a hand at it too. The colder it is, the higher the starting voltage. As the vehicle warms up or as ambient temperatures are higher the operating voltage drops and also the starting voltage will be less (warm start). 13.2 is above the minimum of 12.6 and seems about right if the engine is warmed up and its not freezing cold outside. Fire up a bunch of power hungry items and seem how well it holds. There might be a drop but it won't be much, more so at idle. While driving there should be little to no drop with a bunch of stuff powered on.
DiscoIIBrandon
03-14-2012 07:26 PM
