warranty
Old Feb 15, 2009 | 05:27 PM
dragan's Avatar
Default warranty
Do anybody no how is Ford esp warranty with paying a clam.
Quote from Ford ESP warranty is
7 yrs / 100,000 miles / $100 deduct. $2,920 - $180 = $2,740
Old Feb 16, 2009 | 02:58 PM
Jantiz's Avatar
Have not used it yet. Still under 50k
Old Feb 16, 2009 | 07:41 PM
dragan's Avatar
If I understand correctly you did bay FORD ESP WARRANTY
Old Feb 18, 2009 | 12:47 AM
eshew's Avatar
$2.7k is alot to pay for something you might not use.
Keep in mind the company offers this service to make money, ie most people wont accrue anywhere close to $3k in repairs due to failure within 100k miles.
Just read up and keep up on your service guidelines and you'll be ok.
If anything I would suggest spending some money on a real Factory Service Manual so you can do the simple things that can reduce the really costly repairs...ie trans fluid/filter changes, differential fluid changes, and transfercase fluid changes. Also engine oil and coolant changes and brake pads/rotos/sensors.
Everything else ie water pump and alternator cant really be serviced, just run till they break.
Doing this stuff yourself makes you more familiar with your ride, proud of the work you did and less likely to take the BS the dealers throw at you as gospel
Old Feb 18, 2009 | 01:09 PM
Ford and GMAC are 2 of the best and most reasonable, Rover might be better but now that TaTa has taken over, their policys are way to expensive.
kuttnerbuck
May 8, 2014 06:58 AM
kpxus
Jun 16, 2005 11:14 PM
mmeyer
May 26, 2005 02:06 PM
Newfoundlandrover
Mar 23, 2005 11:46 PM
thansaffel
Mar 18, 2005 04:38 AM
