Water Depth
Old Jan 11, 2008 | 05:24 AM
rbelz's Avatar
Default Water Depth
When looking at my LR3 information, it frequently mentional a very high water fording depth capability. Looking at the illustrations, the water depth is pretty much up at the top of the STD tire rims, which puts it what appears to be a couple inches up above the bottom of the door sils. For those of you who have attempted it, does the LR3 door seals manage to keep the water out so that it does not pour in around the floor mats. I'd assume that must be the case, but just did not want to find out the hard way.
Old Jan 11, 2008 | 05:43 AM
Randy Lover's Avatar
Default RE: Water Depth
with the air suspension in off road mode you can ford to an recomended depth of 700mm. i imagine slightly more than this would be a major problem
Old Jan 11, 2008 | 08:34 AM
lrcb40's Avatar
The seals are very capable of keeping the interior dry. I've seen an LR3 up to the top of it's wheels with nothing inside.
Old Jan 11, 2008 | 09:03 AM
drzjoint's Avatar
i beleve the seal is fairly tight. they use alot better seals than what we use over here. i have seen a jag turned into a swimming pool with verry little water leaking out; you could actually fill up the inside with the doors closed. so a little h2o over the bottom of the door should be ok its not like you are parking it their for a week and the vehicle will be moving so you should stay dry.
Old Feb 15, 2008 | 10:12 AM
*i mean to say it would not be a problem [/align]
Old Sep 9, 2008 | 08:44 PM
petty's Avatar
ORIGINAL: rbelz
Fording depth is important if you plan to cross creeks and streams along a trail. I think it was 30 inches or 24 inches at 5mp.
discoboy
Dec 20, 2012 02:24 AM
yoshibond
May 12, 2012 05:19 PM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
allstarbiker592
Dec 21, 2006 06:45 PM
