Weird starting issue
Old Mar 21, 2024 | 10:15 AM
Columbiar's Avatar
Default Weird starting issue
Just recently getting an intermittent starting issue. Sometimes when I turn the key, it will begin to turn over, pause, and then continue. It will indicate a transmission fault, special programs off, etc. if I turn the truck off and restart, all is good.
I’d be thinking battery but it doesn’t labor when turning over. Perhaps the starter?
Old Mar 21, 2024 | 07:58 PM
scooterforever's Avatar
Check your battery terminals. Corrosion can have that type of impact on starting, and is an easy fix. Last time I thought my battery was on the way out, it was only the terminals and after a minute of cleaning, startup issues were gone. Could be other things of course but corrosion is easy to check.
Old Mar 21, 2024 | 09:09 PM
Columbiar's Avatar
Good point. I should have thought of that.
Old Mar 22, 2024 | 10:03 AM
douglastic's Avatar
Some thoughts:
- bad battery
- 400 amp fuse on the positive terminal
- ground cables bad connection/corrosion to frame/body
- dying starter or solenoid
Old Mar 22, 2024 | 10:07 AM
Rufflyer's Avatar
One of the "habits" I have adopted over time is to turn the key to "on" and wait a second or two before moving it to "start" . This does a few things like let the fuel pressure come up and let all of the ECU's check in during the systems check.
Not saying this is your problem, as a bad terminal or cable seems to be the most likely issue.
Just throwing that out there as a common practice to avoid startup issues.
Hope this helps
Jeff
Partyof6
Jul 6, 2022 04:59 PM
AmericaLandLR3
Aug 17, 2020 07:38 PM
nooath
Apr 27, 2014 02:53 AM
dcmulisha
Sep 21, 2012 08:25 AM
Jerover
Aug 17, 2008 10:42 PM
