Went Into Low Range On Its Own
Old Feb 8, 2020 | 02:08 PM
KPatterson's Avatar
7th Gear
Default Went Into Low Range On Its Own
2006 160k
Parked over night started just fine the next morning. Green low range light is lit up on the dash. Put it in N hit the switch to go back into high. Nothing! Stuck in low, shifts fine, runs fine. Switch is getting power.
I`m going to check the connections at the TCCM tomorrow. Any other suggestions?
Old Feb 8, 2020 | 08:17 PM
DakotaTravler's Avatar
So its mechanically stuck too? Are the rest of the systems aware of the issue, in other words is the car complaining in the message center in any way? Have you tries a rolling gear change, you can switch from high to low up to 35mph I think - I always change when moving.
Otherwise I would say try to disconnect the TC case harness under ht vehicle, check it over, re-seat it. Just doing that may take care of it. If not, can you pull codes?
Old Feb 11, 2020 | 10:09 AM
KPatterson's Avatar
7th Gear
I can`t even hear the gear selector underneath. Usually I can, so its not even trying. I`m going to try some diagnosing this weekend when the weather clears. ......Hopefully
Old Feb 11, 2020 | 10:59 AM
houm_wa's Avatar
Have you tried a hard reset?
Old Feb 11, 2020 | 11:03 AM
KPatterson's Avatar
7th Gear
Yes I did
Old Feb 29, 2020 | 02:27 PM
KPatterson's Avatar
7th Gear
Good news, tracked the issue down to a bad electrical connection at the harness going to the center console switch panel. Do some mild sand paper and electrical spray. Cleaned the connections up. Good as new.
Old Jan 5, 2021 | 07:15 PM
Kendallwilcox's Avatar
Default I have the same problem...
I have the same problem... Where exactly was the connector?
Old Jan 5, 2021 | 07:16 PM
Ghaniba
Apr 28, 2020 10:19 PM
grammin
Apr 21, 2020 09:20 PM
tombartley
Sep 15, 2014 06:18 AM
wilson96rr
Jan 3, 2009 10:44 AM
samsly
Nov 25, 2007 08:04 AM
