Were is the window module?
Old Mar 12, 2021 | 06:18 PM
Perfectphoto's Avatar
Default Were is the window module?
My rear windows don't go down and I can't seem to find the window module. If someone could tell me where to find that on my 2007 it would be much appicated.
Old Mar 12, 2021 | 06:34 PM
DakotaTravler's Avatar
I am pretty sure windows are ran from The BCM (Body Control Module). I could be wrong, would have to look at wiring but that is what I recall. Nonetheless the modules is really, if ever, at fault. I would pull the switch pad in the driver door and verify the lock-out switch is not defective, they do fail. But first you can try holding the down button for a minute or two. Basically for a stupid long time and see if the window comes back to life. It apparently forces some sorta reset. Sorta like how an inoperable sunroof also resets with this method.
Old Mar 12, 2021 | 06:40 PM
I have tried holding the window switch in the down position for about five minutes and nothing happens. I will try to take the drives door switch apart and see if I can see anything.
Old Mar 12, 2021 | 06:46 PM
Did some digging for ya, see if any of this can help. Look like they actually most route to the central junction box. I learned something new tho, each window has its own separate fuse. There is also a relay, so check that.
Old Mar 12, 2021 | 06:57 PM
I just pulled the drivers door switch and I could jump the front window with a test light and make them go up and down, I can't make the rear move back jumping them like I can from the front windows.
Old Mar 12, 2021 | 07:01 PM
Try jumping the switch isolator and then jumping the rear windows.
Old Mar 13, 2021 | 10:51 AM
I just tried jumping the isolator switch and then jumping the rear window, nothing. I looked at the wiring diagram and I really don't know how to read this kind of stuff. It just seems weird that both windows don't work.
Old Mar 13, 2021 | 11:43 AM
pagoda's Avatar
I don't suppose the rear window lock is activated? Worth checking that.
Old Mar 13, 2021 | 02:19 PM
Not sure what you mean by rear window lock? The lockout from the driver's door has been checked.
Old Mar 13, 2021 | 07:15 PM
I can only think its some sorta damaged wire. If power is provided via a junction in the sills and there has been water damage, then I would start there.
