What hose is this?
Old Jul 27, 2019 | 10:35 PM
Philip Chan's Avatar
Default What hose is this?
I notice come coolant leaking on the driveway today. This hose that connects to the thermostat (see pic) was leaking from the jubilee clip.
I cut it shorter and reattached protemp.
What is the hose that I need to reattach? And where does it attach down below?
Is it it safe to drive with it attached shorter?
Leaking from here.
Piece that was worn away
This is the hose what is it called?
Old Jul 27, 2019 | 10:40 PM
Should be the bleeder line that has the T fitting. Goes down under the manifold. Should be fine to drive like that
Old Jul 27, 2019 | 10:55 PM
Thanks. Hard to figure out when I'm looking at pictures and it doesn't look like the hose that I have at the moment...
It's this one...right? https://www.roverparts.com/Parts/LR006158G
Old Jul 28, 2019 | 06:00 AM
That would be it
Old Aug 1, 2019 | 09:46 PM
That would be it
So I had to replace it - the end was too far gone and it sprang a leak.
Question is. - how the hell do you replace it? I can't figure out where the other end goes. the manifold? how to get to it?
please help!
Old Aug 4, 2019 | 05:58 PM
bchriste's Avatar
6th Gear
please help!
What did you find out? I am in the same boat. Thanks!
Old Aug 4, 2019 | 06:21 PM
bchriste's Avatar
6th Gear
Whoops, Missed it in the search. Here is a good post with a picture: https://www.landroversonly.com/forum...a-only-145082/
Old Aug 5, 2019 | 09:40 AM
Hi. So as a temp measure I connected the end of the hose to the thermostat then spliced in with the existing hose that goes to the manifold - until I can figure out.
So I was also told by Atlantic British that taking the throttle body off would give me access but I just don’t see how this is possible. I am thinking the intake manifold has to come off.
I could be wrong and and would like to be so.
Any way let me know how you tackled this.
Army ranger - if taking off the manifold , how best to do this?
Old May 11, 2022 | 11:58 AM
Greg-2022's Avatar
Did you have to remove the intake manifold to replace the coolant hose?
Old May 11, 2022 | 05:42 PM
DakotaTravler's Avatar
It helps, a lot, but no. You can remove it by carefully sliding it back once the clamp is free. Then you can attach strings to the new one as a way of pulling it once lined up. You have to lubricate with straight coolant or something that will dissolve easily once coolant is in the line. But basically line it up very carefully then pull the strings to pull the line onto the nipple. It can help to slightly trim the hose opening and make the last 1mm of it a little wider. Obviously the t-stat housing/crossover tube has to be removed for this - best to put a new one in.
