Wheel Hub
Old Mar 22, 2012 | 08:28 PM
Rover Family's Avatar
7th Gear
Default Wheel Hub
Greeting everyone! Hopefully this isn't a repeat from any earlier threads, but I thought I'd share my latest wrench-turning story with you...
I have a 2007 LR3 with about 90k miles. A constant grinding noise started coming from the front driver's side wheel. Since it did not change with the application of the brakes, I was thinking it might be the CV axle. When I raised the vehicle, I noticed there was a lot of play in the wheel, so I went to my favorite car parts web sites and started shopping. I ordered a wheel hub on Monday and received it today, making for a nice little afternoon project.
The reason for the post is just to provide a couple of quick tips if anyone else takes on this project...
The brake pad sensor is extremely fragile! Be careful when you remove it and don't pry on it with anything!!! Disconnect the bolt that holds the sensor cable and brake line before unbolting the caliper. Also, don't forget to have a coat hanger wire ready to hang the caliper once it is unbolted.
The rotor did not want to come off the hub... Even after applying WD40, it didn't want to budge. An 8" gear puller did the trick just fine. I used the same gear puller to push on the axle to separate it from the hub once I removed the axle nut.
The axle nut requires a 32mm socket. Sears had one for about $10. The main reason for disclosing this is because it was a bit of an educated guess on the size. I did a little searching on the net prior to buying the socket, but I was unable to find anything giving the exact size of the axle nut for my LR3.
The specs for the LR3 state that the axle nut needs to be torqued to 248 lb-ft. My torque wrench does not go that high. I maxed it out then used a breaker bar with a pipe to give it just a bit more twist.
All that being said, the road test went great! The noise is gone and I gained a little experience along the way. If you have to take on the same project, I hope my tips help!
Old Mar 23, 2012 | 06:28 PM
threalassmikeg's Avatar
Nice write up, and... Congratulations!
Old Mar 25, 2012 | 04:29 PM
Rovin4life's Avatar
always have a soft blow mallet to take off the rotors when seized.
Old Mar 4, 2013 | 08:48 PM
tmtegt's Avatar
5th Gear
Default replacing front wheel hub
I came across a post stating that while a 32mm socket is called for to remove the axle nut, a 1.25 inch socket has a snugger fit. I tried both, found it to be true and used the 1.25 to remove the nut,
Can anyone tell me what size 12 pt socket is required to remove the caliper bracket? a 13/16 inch socket fits but not snug, a 20mm 12 pt box wrench is too small.... unless my math is off a 21mm is larger than 13/16....
Old Mar 5, 2013 | 06:06 AM
21mm..
Old Mar 6, 2013 | 07:53 AM
tmtegt's Avatar
5th Gear
Default wheel hub
just an update....
just finished the repair,
The 1.25 inch is the socket of choice for the axle bolt, and the 13/16 works best on the caliper bolts and use lots of wd-40 especially on the hub bolts as the extend 1/4 inch leaving threads exposed to everything the tire kicks up.... Thus can be a bear to remove let alone loosen.
Disco Alan
Mar 27, 2009 07:50 PM
Quiksilver1850
Nov 25, 2008 01:05 PM
Tvdmtac
Sep 18, 2008 07:17 PM
bmayer01
May 11, 2008 10:38 AM
Disco Doc
Jan 10, 2008 01:17 PM
