Wide Rims = Narrow Sidewalls
Old Jul 27, 2018 | 03:14 PM
Columbiar's Avatar
Default Wide Rims = Narrow Sidewalls
I’m guessing that Land Rover started moving toward large rims only for the “looks”. Of course the look of an off-road truck with narrow little sidewalks is in the eye of the beholder. Im thinking of moving up from my D2 to an LR3 and am wondering if the lack of sidewalls on standard LR3 tires really limit the truck much in most moderate off road conditions? I’m not generally one to install lift kits and all of that. On my D2 I’ve been satisfied with what it can do stock and I’d probably do the same with an LR3. So, are the skinny tires actually really that limiting in most off road circumstances?
Old Jul 27, 2018 | 03:17 PM
You can get where you need to go with a decent set of all terrain tires in a stock or nearly stock size.
Old Jul 27, 2018 | 03:29 PM
houm_wa's Avatar
Most of us switch to 18" rims (if we started with the HSE's 19s) and that is usually enough sidewall.
Old Jul 31, 2018 | 07:51 AM
Blackngold77's Avatar
I had no trouble fitting Nokian Rotiivas in 265/60r18 with no lift.
taken some hard bumps and have yet to have any rub vertically or turning. added benefit they're A/T tires that also have the snow/ice snowflake rating
Old Aug 6, 2018 | 02:49 PM
m_lars's Avatar
I’m pretty sure the reason for larger diameter wheels industry wide is bigger brakes. The look certainly doesn’t discourage the trend.
Old Aug 7, 2018 | 03:52 PM
Columbiar's Avatar
Good point on the breaks. Didn’t think of that.
Captain.Knots
Jan 11, 2019 02:56 PM
gr8tr8
Sep 17, 2017 10:17 AM
Vincent Joseph Vernet
Jan 13, 2014 11:17 AM
ogden45
Dec 31, 2012 12:52 PM
TheQ
Tires
Feb 9, 2008 06:33 PM
