Windshield Cowl
Old Nov 27, 2021 | 02:10 PM
wichipong's Avatar
Default Windshield Cowl
Do you replace the whole cowl or just try to “fix” it by installing new weather stripping? Wanted to check here before i hack and attempt to do either… parts is not that expensive, just a hassle getting one due to no storage space..
Old Nov 27, 2021 | 02:16 PM
will@europartsandoverland.com's Avatar
Considering what can get damaged by a leaking cowl on the LR3, I would recommend replacing it rather than trying to cobble one together.
Old Nov 27, 2021 | 03:14 PM
DakotaTravler's Avatar
Replacement is best with a REALLY GOOD sealant. I replaced mine with a new one shortly after getting the truck. It warped in a way that resulted in water soaking my HVAC filter. I installed a shield on my intake but now a few years later my cowl is warping again. The sealant I used did not hold. I plan to get yet another new one and used a proper 3M windshield sealant this time. In the mean time you can use cold weather electrical tape. I had that installed for a few months with no issue until cowl replacement. Its black, so you won't notice it, and held incredibly well.
Old Nov 28, 2021 | 11:33 PM
wichipong's Avatar
how does the shield look like? Ordered a cowl from FCPEuro wont get here until about a week...
Old Dec 1, 2021 | 02:05 PM
joenolr's Avatar
6th Gear
Just replaced mine and none of the youtube videos use a sealant. Is it necessary? I'm just being lazy because I don't feel like popping it off again if I don't have to.
Old Dec 1, 2021 | 03:05 PM
wichipong's Avatar
I guess they add sealant because of the probability that it will warp again in the future? I might put one if I am able to get my hands on some.. but so far here in the Bay Area California, it hasn’t been that wet.. might skip it…
Old Dec 1, 2021 | 03:23 PM
houm_wa's Avatar
Let's just say it's HIGHLY recommended.
Old Dec 1, 2021 | 04:36 PM
wichipong's Avatar
what sealant do you highly recommend? Permatex? 3M?
Old Dec 1, 2021 | 05:17 PM
houm_wa's Avatar
I think I used an RVT by Permatex; but I don't know enough about the different brands to recommend one. Honestly, the sealant will:
1. Slow down the warping.
2. Help with the water ingress.
Key thing on #1 is keeping it out of the sun. Key thing on #2 is creating a shield for the pollen filter box so that the water sneaking past the cowl isn't as big a deal.
Old Dec 1, 2021 | 06:08 PM
wichipong's Avatar
So do you add the sealant on the windshield side of the cowl or just the filter area?
