Windshield Replacement OEM or AM
Connectors should be there you likely just need to install two fuses in the engine bay box and a relay. Then you need to change the HVAC controls for one with the switch and I would guess that maybe a CCF change with the GAP tool but I think I recall reading that may not be needed. If anything, pull the a-pillar interior trim and just see if a connector is there.
