XY Gear Selector doesn’t seem to calibrate, help!
Old Feb 26, 2023 | 10:58 AM
oxtobyd's Avatar
8th Gear
Default XY Gear Selector doesn’t seem to calibrate, help!
So, have a LR3 manual tdv6 2005. It has the gear selector on the dash taking a few seconds to register, so throws the Amber parking brake light on the dash and a transmission fault (code reader points to xy gear selector), and reverse lights don’t work until clutch fully released for at least 1-2 seconds.
I’ve run through the xy gear sensor calibration routine as found on the forum and in the LR Workshop manual, but still have the problem, so now not sure what to try next, any pointers? (I wonder if the calibration is taking, or I’ve read a few times about update the software on the sensor but no idea how to do that)
Don’t think it needs a new xy sensor (I hope as not sure how to change it as located top of the gearbox) as it will register gear when clutch fully released after 1 or 2 seconds.
Help!
Old Feb 26, 2023 | 06:49 PM
loanrangie's Avatar
No manual option in North America and Australia only got a handful in 2005.
Old Feb 5, 2025 | 01:57 PM
RondLaver's Avatar
Help!
Did you get this solved?
Old Feb 5, 2025 | 02:13 PM
oxtobyd's Avatar
8th Gear
Sadly no, i just live with it, since I literally tried everything bar changing the clutch and also the actual xy sensor.
Old Feb 6, 2025 | 05:30 PM
loanrangie's Avatar
You will get better assistance on the Disco3 UK forum as the XYZ problem comes up a lot.
kb24
Mar 8, 2016 08:31 PM
Nathan King
Dec 30, 2013 01:07 PM
Big nic
Feb 11, 2013 03:52 PM
premsig
Defender
Dec 30, 2008 10:37 AM
rumpig70
Nov 15, 2007 03:22 AM
