yea more codes !
Old Aug 17, 2015 | 03:45 PM
TOM R's Avatar
Default yea more codes !
Well the 05 had a hiccu earlier today that self cleared, went out this afternoon and as my wife parked and got out dash went haywire, hdc suspension down trans disabled ugh not again say it ain't so
I pulled some codes
Uo122 dynamic control module missing?
Uo416 variable control module
Uo121 abs module
Po504 brake switch a / b signal corrilation?
I am sure there's more, pulled pass side kick , everything seems OK, pulled the sill and tugged on the splices nothing came apart, all my problems thus far traced back to these areas
Any ideas?
Old Aug 17, 2015 | 05:39 PM
Alphamale's Avatar
Worth checking both battery condition and alternator out put. The lack of good charge in the battery has been known to cause problems in these systems. It happened to me various systems would flag up a problem, even went into limp home mode a couple of times, with no other obvious cause, changed battery and problems stopped. That was 3 months ago.
Old Aug 17, 2015 | 05:44 PM
TOM R's Avatar
We were driving a few days ago and the dam touch screen kept turning on, then started flipping through options wtf
Old Aug 17, 2015 | 05:52 PM
Alphamale's Avatar
Again a low charge problems can cause all sorts of system problems. Using a multi-meter check battery capacity with engine off, then with engine running. IIRC with engine off battery should show something like 12.6v and with engine running you should get around 15+v unless alternator is faulty.
Old Aug 17, 2015 | 05:58 PM
TOM R's Avatar
13.9 volts at battery connections tight, no load
12.64 engine off
Old Aug 17, 2015 | 08:02 PM
TOM R's Avatar
So is there some way to be sure the alt is bad besides voltage test at idle since iirc the ecm is the voltage regulator?? Before I drop a few hundred on an alt
Old Aug 17, 2015 | 08:53 PM
unseenone's Avatar
Voltages seem in the range. As I recall you've done significant rewiring on this thing from various problems... I would first be looking at the connectors and brake light switch / wiring (I imagine you put a new switch on) and ensure all the brake lights are actually working.
That's my 2c to start..
Alpha might not know the background on this, but I consider his opinions seriously.. but... 15+v no-- not here are least. The only time I got up to 14.9 then 15 was with a bad battery. Luckily I have circuit protection for all my toys, so it kicked in and shut off power..
bbyer is the charging system guru of sorts here... but I suspect it's related to something else.
Old Aug 18, 2015 | 07:15 AM
TOM R's Avatar
Yeah I did switch and bulbs from stealership, all the codes are brakes , park brakes, and abs like it can't see the brake system
Old Aug 18, 2015 | 10:27 AM
TOM R's Avatar
Well this morning started rover, lights on, walked away for a few came back to move it lights out, hit it with scanner every system had same code saved, no communication with variable control module , did global etc clear and went for a drive all is fine I hate this trucks hissy fits
What's the. Variable control module? Since seems it is the issue
Old Aug 18, 2015 | 11:38 AM
cmb6s's Avatar
I wonder if this may be a high speed canbus issue. I know there have been posts by roverguy7 in the past on troubleshooting canbus problems. You may want to dig and see what you can find.
