Zip kit and still a 2-1 kick?
Old Jul 13, 2025 | 08:43 PM
  #21
loanrangie's Avatar
Originally Posted by He11R3
I did do the first section of the adaption process when I first replaced the solenoids. I managed 1 round of the fifth gear adaption and a few sixth, but it would take several hours to get through those unless you lived somewhere flat. It is shifting perfectly now.
If I had another similar issue I would skip the kit and just replace the bridge seal/tubes, separator plate, and solenoids.
If you were able to test the valve body for leakage using a vacuum test then you could skip fitting the zip kit, would be a pita to get it all back in only to find that it was leaking.
sickws6
Jan 16, 2021 10:56 AM
abran
Oct 14, 2014 09:09 AM
buick215
Jun 26, 2013 11:14 PM
ara25
Mar 25, 2011 08:27 PM
