2010 LR4/Need rec for LED turn signal for front light
Old Nov 22, 2014 | 09:12 AM
jrotter's Avatar
Default 2010 LR4/Need rec for LED turn signal for front light
Hello, can anyone recommend a LED turn signal for my 2010 LR4. I bought one but the socket didn't fit.
Thanks
Old Nov 24, 2014 | 09:23 AM
Neb's Avatar
Neb
You could try:
deAutoKey ? Home
I know the focus on VW/Audi but they would be a good start. I'd just give them a ring. From a quick google search the bulb looks to be a 12V 5W Standard 2827 Bulb
Old Jan 21, 2015 | 09:41 PM
scaredasno's Avatar
I found some for my 2006 LR3 at either CARid or VLED. Can't remember which one. Just type in the part number from your original bulb and it will pull up the LED equivalent.
Old Mar 17, 2015 | 11:42 PM
PDXLR4's Avatar
Have tried Super Bright LEDs? They have most of the bulbs in stock for LR4s and give a nice list of different bulb locations throughout the vehicle.
https://www.superbrightleds.com/cat/...acement-bulbs/
Old Mar 17, 2015 | 11:43 PM
PDXLR4's Avatar
My bad... see they don't carry the turn signals...sorry.
Old Jan 11, 2019 | 08:00 AM
iconoclast's Avatar
Is there a way to disable the led ring completely? I do not want these "ben wa ball" inspired lights on at all and would prefer they be disabled permanently.
Currently the LED is off unless headlights are on. I would like them off even with the headlights.
If there isn't a coding option could I change the pin-out on the harness?
Old Jan 11, 2019 | 09:06 PM
BritCars's Avatar
I believe the dealer can turn them off altogether in the system
Old Jan 13, 2019 | 06:54 PM
iconoclast's Avatar
thanks, i will ask on my next visit but curious if there is something that can be done manually.
the led are connected to the corner marker light in the headlight so i have to imagine if you code that off it would turn off the led but without coding is it possible to change pin-out or disconnect wire?
Old Jan 14, 2019 | 06:44 PM
BritCars's Avatar
I guess if you can find the power feed to them you could just disconnect them. But who knows what errors that might give so I'd have dealer just turn them off
Old Jan 14, 2019 | 09:16 PM
iconoclast's Avatar
Done.
https://landroverforums.com/forum/lr...-lights-93016/
