2011 LR4 HSE Ticking Noise on Startup
Old Feb 29, 2020 | 09:46 AM
boothannie's Avatar
Default 2011 LR4 HSE Ticking Noise on Startup
My 2011 LR4 has started making a ticking noise on startup. Goes away after about ten minutes. Any ideas what this is? Thanks in advance for any help.
Old Mar 2, 2020 | 11:42 AM
John Fischer's Avatar
5th Gear
Mine does this same thing! Almost only when it's very cold, hasn't happened in the summer.
I've so far found no exact cause but my suspicion is that the fan clutch is failing to disengage at very cold temperatures.
Old Mar 2, 2020 | 12:33 PM
boothannie's Avatar
Interesting! The mornings I have only noticed it recently and the weather hear has been extremely cold some mornings. As the weather temps get warmer here I will see if it continues. Thx for the reply. We checked everything over and didn't notice anything amiss ourselves.
Old Mar 2, 2020 | 12:50 PM
WILLPULLEM's Avatar
Have you had your timing chains guides and tensioners replaced yet?
Old Mar 2, 2020 | 01:11 PM
boothannie's Avatar
Not yet.
Old Mar 2, 2020 | 01:28 PM
boothannie's Avatar
Current temp is 53 degrees. Just started it from cold for the first time today and no ticking. A quick internet search has me leaning towards fan clutch noise.
Old Mar 2, 2020 | 02:04 PM
5th Gear
I had my chain, guides and tensioners replaced last year when I bought the vehicle. So I'm fairly sure it's not that, unless the dealer's shop messed up, but I had the work inspected by a reputable indy shop here.
Old Mar 2, 2020 | 02:38 PM
WILLPULLEM's Avatar
I think the pace of it is too slow to be chains or guides. I was just curious with mileage you reported if they had been or not.
Old Aug 20, 2020 | 08:55 PM
January Cross's Avatar
It’s your radiator fan. Viscous fan. Im on my second Rover that had this issue.
Giverny03
LR4
43
Aug 27, 2025 01:00 AM
Luis Fernando Gutierrez
LR4
76
Apr 15, 2022 11:22 AM
iconoclast
LR4
Nov 16, 2017 07:20 AM
jrobey
Oct 1, 2017 01:46 PM
Kingfish
LR4
Jul 5, 2012 08:24 AM
