2011 lr4 rear hatch issue
Old May 9, 2018 | 10:03 PM
ForgeDetroitCustomKnives's Avatar
Default 2011 lr4 rear hatch issue
Hello all. Newbie here ! I have a 2011 Lr4 having issues with opening the rear hatch! I have checked the cable to the actuator and everything seems to be connect and working. Here’s the issues
1. I cannot open from the outside. When I hit the outside button to open I can hear it but it doesn’t open
2. If I don’t slam the hatch hard enough a “hatch open” light comes on
called the dealer. They said it was the actuator
any help would be great. Thanks !
Old May 13, 2018 | 12:20 AM
Greggles's Avatar
Do you doubt it's the actuator?
I've replaced both the actuator and the latch on a RR. If I remember correctly you can remove the unit and plug it into the other side and confirm that it's bad.
Certainly a DIY
Old May 13, 2018 | 12:28 AM
[QUOTE=Greggles;647450]Do you doubt it's the actuator?
Ill have to try that ! Everything seems to be moving when I hit the bottom but never really thought about the latch !
richs
LR4
Aug 7, 2017 02:00 PM
Sbmargo
LR4
Jul 20, 2013 10:01 AM
allwood2006
Jan 28, 2012 08:42 PM
asmithcash4real
ROAMING WITH FRIENDS
Jul 4, 2011 07:27 PM
dr.brillo
Jun 8, 2011 06:29 PM
