I replaced the water pump - Still leaking- questions
Old May 20, 2018 | 03:22 PM
PDXLR3's Avatar
5th Gear
Default I replaced the water pump - Still leaking- questions
So I used the Water Pump DIY and it was very helpful. Ran into a few rough patches but all in all it was pretty straight forward. I replaced the pump and got it all back together and filled with fluid and it started leaking again all over the shop floor. Couple of questions:
-Should I have used sealant on the gaskets? I did not but looking back perhaps I should have. There was no sealant on from the factory so I assumed I was good to go.
-Looking at the pump from the front it appears the leak is from the bottom left hand side but to the right of the lower T30 bolt.
-I also notices the small black plastic fitting that pushes into the water pump (the one many people have broken) is leaking a little bit. Has anyone found the replacement part number for this piece yet? Should I put a little sealant on this as well when I push it back in?
- Any other thoughts or things I should check?
Edit: I took the pump off again. When I reassembled I put a new o-ring/seal on the tube coming off the engine where the plastic tube plugs on. I put the other o-ring/seal on the smaller end of the plastic tube and then inserted the tube onto the motor. I made sure the gaskets were lined up and on correctly when I put the pump on. Torqued everything to spec and reconnected the hose to the water pump. I fulled the reservoir tank up again and it still is leaking considerably. I am 99% sure it is not from one of the gaskets/ports. It is basically coming from directly behind the pulley and running down the block. The galley where the tube plugs into the block is full of water/coolant. Was reading about a failing cross over tube under the intake manifold.
Any other ideas?
rossagge
Mar 10, 2017 02:16 PM
lrjon
Mar 9, 2017 05:36 PM
Intellius
Jun 28, 2011 07:55 PM
Bryan H
Oct 11, 2010 06:07 PM
