2012 LR4 Engine swap worth it?
Old Dec 8, 2022 | 10:29 PM
BenV's Avatar
Default 2012 LR4 Engine swap worth it?
First Time Poster, hope this is the right place for this question; my wife's 2012 LR4 recently had the coolant low light come on while driving. long story short- went from a possible failed water pump, which we replaced along with several other things, to now the head gasket is gone and the engine needs replacing. Never had so much as a high temp warning, and sadly the extended warranty i bought when purchasing it, won't cover damage due to heat. so, we're sol. Dealer/mechanic say it's roughly $17K for a new motor installed, and before i pull the trigger, I'm trying to find out how wise, if it all, it is to do so. my wife loves the car, and uses it all the time to haul 3 kids around. the car is at 105K miles, and I'm nervous that after dropping almost $20K on a motor replacement, we'll be looking at an increasing list of expensive failures as time goes on, maybe even soon. we take good care of it; regular preemptive service, nothing skimped, no more than 3K miles between oil changes, anything thats been wrong we fix, and have never had any issues until now. I bought it when it had 70K miles on it, so not the only owner, but, it was in great shape, and only one owner before. I've found a motor with 54K miles. Any advice?
Old Dec 11, 2022 | 02:20 AM
AGLR's Avatar
I rebuilt my 2011 v8 by myself. No experience, just time and a desire to learn. So far, so good at about 20k miles since then. About 3k in parts. We don't all have the time, and other options need to be considered...
How bad was the failure? Is it still running but losing coolant, or a complete failure?
Though dealers typically won't do a rebuild, perhaps yours could be saved by a good independent shop?
Also, you said 17k new, installed. Then you mentioned you found a motor with low miles. Is the 17k actually a brand new motor?
AGLR
Old Jan 3, 2023 | 10:32 AM
iceman_13's Avatar
3rd Gear
Hey Ben - I may be in a similar situation. Engine overheated a year ago, replaced the crossover valve, was working fine, ~9 months later the water pump failed, then the replacement failed, and am now driving with a new water pump. I am curious how you knew the engine was ultimately fried - what test did you do? My car is working totally normal other than a strange coincidence of coolant issues in the last 12 months.
Old Jan 21, 2023 | 02:50 AM
M32H32IS's Avatar
Look up Ronda Used Auto Parts in Houston.
they swapped a reman 5.0 for me this summer for a little shy of $10k and I’m loving it! Just like new.
feel free to PM for Q&A
Old Jul 12, 2025 | 10:09 PM
JBelt01's Avatar
Older post, but did Rhonda perform the swap themselves in house? That’s an excellent price.
(I was just quoted $30k by the dealer, and $24k by a reputable indie. Most won’t touch it.)
knightmetro
LR4
25
Mar 15, 2023 10:51 AM
Petunia
LR4
31
Oct 8, 2022 06:50 PM
JCAR1
Engine Swaps
Sep 3, 2021 11:25 AM
_Gex_
LR4
Jun 17, 2021 10:59 AM
evrclear25
LR4
Feb 21, 2017 10:17 AM
