2012 Overheating P0128 P003C
Old Aug 16, 2025 | 02:07 PM
Lander454's Avatar
4wd High
Default 2012 Overheating P0128 P003C
Just bought a 2012 LR with 5.0. These codes showed up P0128 P003C and it’s overheating. Changed the oil and the P003C and red triangle went away. Now I need to deal with the overheating, seems like the P0128 is the thermostat, looking to order one it seems there are metal and plastic from Atlantic British which one is recommended or from where? Now have only yellow triangle, would the overheating also throw more codes, I feel it needs to bleed the air. It did need coolant when I got it, it sounds ok although I never owned a lr4.
Old Aug 17, 2025 | 06:48 AM
AVLDefender's Avatar
If the coolant crossover pipes have not been replaced, you should probably do those, the thermostat, and the water pump.
Old Aug 17, 2025 | 03:18 PM
Lander454's Avatar
4wd High
Where or link for water pump, thermostat, crossover or maybe brand for parts.
Old Aug 20, 2025 | 09:02 AM
ugmw177's Avatar
many folks buy these from atlantic british. they stock both JLR and oems for a lot of items. FCP Euro may have what you need as well. I would steer clear of the ebay and amazon stuff as you really want oe for the cooling system parts on these vehicles.
Old Aug 20, 2025 | 09:04 AM
ugmw177's Avatar
if it is already overheating and you do not have a leak and you are sure coolant is full with no air pockets, i would check coolant for combustion gasses before i replaced all of that stuff just to be sure you dont have a head and/or head gasket issue.
Old Aug 27, 2025 | 05:01 PM
Lander454's Avatar
4wd High
Thanks for the answers to my questions. Will do the head gasket test, although I already ordered the water pump and thermostat. It looks like it’s leaking from the water pump, used some coolant dye. Today I will look for more leaks.
Old Aug 28, 2025 | 10:30 AM
guy's Avatar
guy
Best do a pressure test. You won't be able to see all the possible leaking points.
Cheers
Bill Miller
LR4
Mar 17, 2020 09:59 PM
Brandon318
Jun 8, 2019 05:41 AM
Mooseman
May 28, 2019 03:08 PM
holland
Freelander
May 13, 2009 02:57 PM
paweliania
Freelander
May 2, 2008 10:02 AM
