2014 lr4
Old Dec 26, 2022 | 11:55 PM
  #21
Jardus's Avatar
5th Gear
hi
check engine compartment fuse and relay box.my preview post that I fixed it by changing relay works only for few thousand miles.It was not the relay what cause the problem,but the wiring.
You have to open the fuse box to see the wiring under and check wire connector feeding ECU relay.It is permanent power from the battery ....thick red wire....with connector connected to aluminum rail .This connector is probably loose .Best way is solder it on the rail.This problem is undetectable by diagnostic,because everything works fine until ECU lost the power for milliseconds .Bad engineering I would say.
Don't be fooled by the fact that the connector looks good..... like me!
Old Dec 29, 2022 | 10:45 PM
  #22
Melody Borrowman Reels's Avatar
Originally Posted by Rush1414
I've had the same problem with my 14 LR4..just dies going down the road or idling..replaced crank sensor, cam sensor, and about to attempt to clean the return line fuel condenser/filter..any help appreciated..also what is your new problem as I can't find the thread
Jardus helped me with my problem, scroll up and you will see his response. Switching the relay fuse from a 40 amp to a 70 seemed to do the trick.
Melody Reels
Old Dec 30, 2022 | 12:09 AM
  #23
Jardus's Avatar
5th Gear
Melody Reels
hi Melody
If it is starts doing again,check my last responce.There was problem with wiring under relays.
Jardus
Herdfan
Jun 21, 2016 02:54 PM
jtrippttu
LR4
13
Dec 14, 2015 12:52 PM
Iron oak
LR4
14
Sep 11, 2014 07:33 PM
Eldonkey
LR4
Nov 30, 2013 11:21 PM
Crimson_n_Rover
LR4
Jan 18, 2013 11:52 AM
