2016 LR4 HSE Coolant Type
Hello,
Trying to figure out what type of coolant to use in my 2016 LR4 HSE. Seen some conflicting information that suggests I need to purchase directly from the dealer. I'm not close to any LR dealer and I'm getting a low coolant error on my display (not seeing any leaks, think it needs topped off), so need to top it off tonight, ideally, as the temp gauge is at about 50% currently. Any help/direction someone could provide is greatly appreciated.
thanks!
thanks!
It should be listed in your owners manual. You have a 2016, are you still under factory warranty? If you cant find the coolant type locally just use some distilled water from a grocery/drug store to top off. I would definitely track down the leak and keep an eye on your coolant level until you do.
calvink
Jun 26, 2017 08:38 AM
