5.0 cooling system vacuum tool, who has one
Old Jun 18, 2021 | 02:36 PM
ljdiscovery's Avatar
Default 5.0 cooling system vacuum tool, who has one
I need to drain and fill the coolant on my newly acquired Range Rover Sport 5.0. The vacuum drain and fill method seems to be the way to go. I am getting ready to buy one but I am unsure which make and model works best on the LR4/Range Rover Sport. There are several brands and models of the vacuum tool available. Does anyone have a vacuum tool and if so are you happy with it. Thanks Phil
Old Jun 18, 2021 | 09:13 PM
Stu Barnes's Avatar
This one works perfectly, I just completed the coolant crossover job on my v6
OEMTOOLS 24444 Coolant System...
Amazon Amazon
Old Jun 18, 2021 | 11:45 PM
thanks Stu, I was looking at that one. I will get it ordered. Phil
Old Jun 20, 2021 | 09:14 PM
Stu Barnes's Avatar
Just remember, after filling :-
"Set the heater controls to maximum.
CAUTION: Observe the engine temperature gauge. If the engine starts to over-heat switch off immediately and allow to cool. Failure to follow this instruction may cause damage to the vehicle
Start the engine and idle until hot air is emitted at the face registers.
Switch the heater off.
Raise the engine speed to 2000 RPM for eight minutes.
Top up as necessary"
Stu.
Old Jun 21, 2021 | 01:42 PM
thank you. Phil
Old Jul 3, 2021 | 11:53 AM
I ended up using a coolant vacuum tool from a buddy that has a Porsche Boxter. It worked perfectly. Seemed to suck most of the coolant out and then vacuumed the new coolant back in. Ran it up to temp and after the thermostat opened had full circulation and virtually no air in the system. So much easier and so much less stress about overheating the motor. I would definitely recommend the vacuum tool for anyone sitting on the fence. Phil
Old Jul 3, 2021 | 08:53 PM
Have that same setup and it's stellar, I use it for every fill up now no matter what vehicle
tom1122
Freelander
Jan 20, 2017 09:33 AM
wrongway1
May 24, 2014 03:09 PM
Cosmic88
Aug 10, 2010 05:24 PM
salve7
Mar 28, 2009 12:33 AM
Lnghrn Disco
Jun 6, 2007 10:26 AM
