ACC after market installation
Old May 17, 2025 | 11:50 PM
bluetembo's Avatar
Default ACC after market installation
Dear all,
I would like to install ACC on my 2014 LR4. I can buy part from eBay. But I am told that connector is not prepare from factory on my 2014 model? Can anyone help please
Thank you.
Old May 18, 2025 | 11:49 AM
DakotaTravler's Avatar
Take a look at these posts. Keep in mind they are for the LR3, not the LR4 but overall the situation is very similar. You WILL need to acquire the proper modules, as the LR3 and LR4 modules use different can-bus types and are not compatible.
https://landroverforums.com/forum/lr...trofit-120014/
This thread is INCREDIBLE long but full of information. Much of the early information was before anyone got something working.
https://www.disco3.co.uk/forum/topic...fc187650b49945
Again those are for the LR3 but you will find your needs are similar. Also did you check for connectors? The LR4 might in fact have them. Only an LR3, only the first couple model years did then were removed. But since the LR4 had ACC as an option (I think) then they connects may all be there along with the wiring.
Old May 18, 2025 | 11:51 AM
Here is some info specific to 2014 LR4s.....
https://www.landroverworld.org/threa...-to-lr4.43663/
Old May 18, 2025 | 12:24 PM
bluetembo's Avatar
Thank you so much. If I understand correctly then it only works with 2015 to 2016 LR4?
payner50
LR4
Feb 27, 2023 11:20 AM
Wasldoug
LR4
May 14, 2021 03:37 PM
Brandon Rosenblum
LR4
Sep 19, 2019 08:31 PM
GeoffH
LR2
Feb 23, 2018 04:59 PM
Mwinget
LR4
Dec 24, 2015 08:09 PM
