Apple CarPlay for 2011 LR4 HSE
Old Sep 3, 2022 | 05:10 PM
WilkyF18's Avatar
3rd Gear
Default Apple CarPlay for 2011 LR4 HSE
Hello all, I am attempting in this post to collect all the information I’ve seen in several other threads on how to update the Infotainment system on an older 2010-2011 Discovery 4 / LR4 to Apple CarPlay. I am located in the United States (US). But I also have a lot of questions for anyone that has installed any of these.
It seems like my model of the LR4 has the older Integrated Audio Module (IAM) LR040663. Which runs the MOST 2.0 network versus the MOST 2.1 network on the 2012 and newer models.
My 2011 LR4 HSE has factory Nav and Backup camera, so in the list below I am going to keep the existing touchscreen and not delve into the “10.4inch tablet replacement screen” options.
The options are:
1) Naviplus (AU) – $681.30 (AU$1000)
https://www.naviplus.com.au/online-s...Kit-p100678231
2) NavTool (US?) - $599.99
https://www.navtool.com/land-rover-l...e-carplay.aspx
3) NAVIKS (US) - $825
https://naviks.com/i-24077786-2010-2...tegory:1149762
4) Unique Auto - $616.92 (535.99 pounds)
https://unique-ad.co.uk/product/wire...is4-2011-2015/
5) 4x4 Shop CA (CA) - $900
https://4x4shop.ca/product/2009-2016...media/#buy-now
Questions:
1.1) NaviPlus seems to have the most forum mentions; however, the return policy is abysmal, and several forum comments talk about having to solder wires for it to power down correctly. Can anyone who has installed this recently comment on if the soldering is still required, or has NaviPlus fixed this?
1.2) Also, here is great post by TahoeDog on installing a NaviPlus in his LR4:
https://www.landroverworld.org/threa...68/post-233244
2.1) Does the NavTool also require the 1-BOX Android Wireless Smartphone Mirroring Kit for an additional $143.99? https://www.navtool.com/1-box-androi...oring-kit.aspx The website is unclear if it’s “required” it is just listed as an “accessory.”
3.1) NAVIKS description says “Must send screen” but there is no further detail on the website. Do you have to remove the screen from the LR4 and send it in to them?
4.1) Unique Autolists as compatible for Discovery 4 2011-2015. We know the Infotainment system changed in 2012, so I doubt this is correct.
5.1) 4x4 Shop says “not compatible” with the ‘B’ version of the infotainment system.
For all 5 systems, do you have to run a wire all the way to the Aux input in the center console for the 2011 LR4, for sound to work?
Any feedback from those of you who have installed these aftermarket systems is greatly appreciated, thanks!
Old Nov 22, 2023 | 12:13 PM
jahank42's Avatar
Did you ever end up installing one of these modules? If so, what was the deciding factor? Thanks
Old Nov 22, 2023 | 04:38 PM
WilkyF18's Avatar
3rd Gear
I never pulled the trigger on any of the options. Didn’t really find one that I felt for sure would work out of the box on a 2011.
Old Oct 23, 2024 | 04:37 PM
NashvilleLR$'s Avatar
I have installed the Naviplus in my LR4. Very happy with it, fwiw.
Old Oct 31, 2024 | 12:32 PM
todtan's Avatar
8th Gear
Similar question here. I was watching a LR4 review from a while back and the review mentioned there was a software update that would enable Carplay and Andoid auto on the stock infotainment system. Anyone know anything about this or was it an incorrect statement. I'm speaking specifically in regards to a 2014 LR4.
Thanks!
Old Nov 7, 2024 | 08:23 AM
Touchdown83's Avatar
Default Naviplus
Do you have HD package? Does naviplus still work for the 4x4 screen?
i installed Carputech CarPlay module and it works perfectly, except for the 4x4 screen button is greyed out. I can view some features via the 4x4 settings screen, but kind of frustrated that the main button doesn’t work.
iceman13
LR4
Jun 7, 2024 07:43 AM
Collin Wickes
Apr 7, 2019 08:13 PM
kamkaz
Audio/Visual Electronics
Nov 1, 2018 11:58 AM
Kingfish
LR4
Jul 5, 2012 08:24 AM
hilltoppersx
ROAMING WITH FRIENDS
Oct 8, 2009 08:21 AM
