Bleeding the cooling system of a LR4
Old Apr 5, 2026 | 01:51 PM
Lupus's Avatar
Default Bleeding the cooling system of a LR4
Hello everyone!
Please someone tell me how to properly bleed the cooling system of a LR4, V8, 5.0 - 2012 after changing the fluid. I can't find any clear information on the subject. I don't have a vacuum device.
Old Apr 5, 2026 | 02:07 PM
guy's Avatar
guy
Of course, you realize that by not using a vacuum system, you raise the risk of an air pocket. And that leads to a risk of overheating.
Here are the workshop procedures
Cheers
Old Apr 5, 2026 | 02:10 PM
pagoda's Avatar
Cheers
What he says^^^^^^^
A vacuum bleeding kit is well under $100 on Amazon and for the time it saves and the fact that you will actually get a properly filled system, it's peanuts. You need to vacuum fill.
Old Apr 5, 2026 | 02:12 PM
Lupus's Avatar
Thanks!
This will do the trick. I'm aware of the risks, but I have no choice at the moment.
Old Apr 5, 2026 | 02:18 PM
guy's Avatar
guy
Note that in the second part of filling instructions, there is a way without the vacuum fill. What's not mentioned is that nearly any time you touch those bleed screws, something breaks or its a bugger to get them to seal again.
AaronHall
LR4
Jan 28, 2025 07:17 AM
kst1980
LR4
Apr 28, 2023 08:53 PM
hawaiianbarbecue
LR4
Jan 8, 2023 04:09 AM
lrexplorer
LR4
Aug 12, 2022 04:43 PM
