coilover shocks and now 4x4
My airbags went south over the winter so put on a set of coil over shocks and all seams fine until I went to put her into 4x4 the other day and get a message that that feature is not available now.
For a little more clarification, I removed a couple suspension fuses with the install of the coil overs so I didnt get a constant error message on the panel.
Anybody run into this and have a possible fix so I can use my 4x4 system ?????
You cannot just remove fuses,you need an EAS override module. Those have built-in software that suppresses EAS-related fault errors and DTCs on your vehicle while retaining all the vehicle's original functions, like terrain response, headlight leveling and information screen functions. The LR3 had a coilover option so it was easier.
You want 4x4 put all the fuses back in.
