Did I Fry my coil driver / ecu?
Just replaced my valve cover and forgot to tighten up the ground wire that bolts into the front of the head. Getting a fault on coil 6 and 8 and swapping them doesn’t change anything.
The exact code is a P0356, permanent ignition coil, primary control circuit open, and it will not clear from my scanner.
I’ve read that the coil driver in the ecu can get fried. How do I test this? If I did, is this where I would get someone to clone my ecu on to another?
Also, there is the slight chance that a rat several wire so my question is, how do I test the water is coming off of the coil packs? With a program for continuity running back to the east you or for Holmes of resistance? Well, I don’t think this is the case I figure it’s worth exploring, but right now, those codes are permanently stored and won’t erase. In my gut tells me it was from the lack of proper grounding.
Extinct
Apr 20, 2025 09:56 PM
chelvey@helveyconsulting.com
Jun 21, 2016 07:43 AM
