DIY: Second Row seat handle replacement
Old Mar 17, 2017 | 09:11 PM
vietec's Avatar
Default DIY: Second Row seat handle replacement
So this may seem like common sense to you guys, but I'm hoping that this may help someone else out there.
Recently I picked up my '11 LR4, and some things I noticed were broken but didn't mind as they were what I thought would be cheap to fix. In this case, the part was $15 and it took me more time to unwrap the part than it did to install it.
The offending article is this, the second row seat handle:
Do not ask me how this happened, I only imagine the previous owner dropped something on it or chewed on it. Who knows. Anyhow, I didn't have a thin yet sturdy enough plastic prybar to pry under the handle, so I started by removing the screw in this picture. You can access it by moving the seat to a midpoint position (so it's not latched up or down):
Next you pull on the side of the assembly that the screw was on, lifting the handle out just slightly, now you can get your fingers under there and pop off the old handle.
At this point, I elected to go ahead and put the new handle on most of the way, just to ensure I don't somehow lose the lever if the seat were to go all the way into locking position:
After that, I replaced the screw I removed, and gave the handle a few good heel-palm-strikes to seat it all the way, and walked into the house mildly disappointed at how easy that was.
My next project/write up will be replacing the key fob body, again may seem easy to most of you, but to some it may not be. Sometime in the distant future: 75,000 mile service interval and reset, whenever my wallet has recovered enough to get my own GAP IIDTool.
TRIARII
Apr 29, 2017 07:23 PM
pilsner
Feb 4, 2017 10:49 AM
acg
Jun 29, 2015 02:18 AM
SoCal Rob
Jun 27, 2014 02:18 PM
templar4
Aug 23, 2010 01:38 PM
