Front door lock screw
My 2013 LR4 did not come with any emergency keys. I noticed that the section of the front door driver’s side handle with the emergency lock was loose and it turns out I can pull it out with no problem. There is apparently supposed to be a T20 screw that you access through the side of the door that holds that mechanism in place. You’re not supposed to back it out all the way when you’re changing the lock, but apparently that’s what happened.
Does anyone know what size screw is supposed to be in there? Can’t find reference to it anywhere.
Thanks for your help!
