Fuel sending unit(s) stopped working after removing Pbrake fuse
Old May 14, 2023 | 11:52 AM
attworth's Avatar
Default Fuel sending unit(s) stopped working after removing Pbrake fuse
Hello folks. 2011 LR4. 173k miles ish.
The parking brake was randomly engaging, and is broken (won’t unlock), so I removed the 30 amp fuse under the hood to get it to stop until I could unplug the actuator.
I’ve since replaced the fuse after unplugging the actuator.
Now the fuel sending unit isn’t working. It’s showing empty. This started after removing the fuse. So I thought maybe they were connected somehow. I checked the fuel fuse under the hood as well, and replaced it for good measure.
Short of replacing the sending unit(s), is there something else I could check? Also, how do I know which of the two is bad?
Thanks for any advice.
jahummer
LR4
May 2, 2023 08:56 AM
Jeandre Clark
LR2
Mar 7, 2022 04:59 PM
disco96sd
Jan 21, 2022 11:54 AM
thisisheaven
Jul 12, 2007 01:03 AM
