How do I test the ECM on the 2010 lr4?
Old Aug 9, 2023 | 12:04 AM
newdude's Avatar
Default How do I test the ECM on the 2010 lr4?
not getting power to cylinder 7. After trial I only have two options left, bad wiring or bad ecm. Im inexperienced to ECMS. What is the pinout for this ECM and how do I test it? On another side note, how much voltage should be coming out of the connector for the ignitor coil?
Old Aug 9, 2023 | 09:42 AM
abran's Avatar
If I remember correctly one pin is battery voltage, one pin is approx 5 bolts but fluctuates based on the firing signal, the other is ground.
If you can back probe a functional cylinder to get values for reference that’s best.
I’ll get eyes on a connector today and see if I can’t tell you wire colors.
hawaiianbarbecue
LR4
Jan 8, 2023 04:09 AM
azontodance
LR4
Oct 13, 2021 11:57 PM
notTHEtoyota
LR4
Aug 15, 2021 08:18 PM
Erwin Perez
LR4
Aug 19, 2019 09:31 PM
iconoclast
LR4
Nov 16, 2017 07:20 AM
