Ignition goes off when trying to start
Old Mar 20, 2024 | 07:15 AM
Youngin's Avatar
Originally Posted by stoksu
yes mate, it was abs pump that does not allow to start if break fluid has not reached correct pressure. I was doing it after lifting the body and all breakes were still disconnected. Ive connected all break pipes bled them up and car started without any issues. Hope this helps in your case
Raf
Please does this work on a Ranger Rover Sports supercharged 2019? Do I have to change the ABS pump or I just have to bleed all the brakes up?
Old Feb 24, 2025 | 07:28 PM
Oj12's Avatar
Default Hi any one found the solution of no crank no start . I ve got l494
Originally Posted by Hotjava69
What ended up being the fix for this? I have the exact same problem on my 17 Range Rover.
Hi any solution a
i am in same situation no crank no start . Only starts by relay short. I got l494 just had full engine rebuild and now it's not starting from button . Pls help as it's getting really frustrating
Old Apr 8, 2025 | 12:46 PM
jemsautorepair's Avatar
Default made this account just to try and help you guys
to compliment the previous posts on this thread.... same condition here at the shop and even on the professional level there is poor support so thought id try and help you guys out..
customer states vehicle has a no crank condition however powers up normally.
when stepping on brake and attempting to start (pushing button while hold brake pedal) vehicle shuts down.
performed dtc scan and no relevant faults, however, tcu (telematics unit) missing during fault scan.
skip ahead and checked voltage at tcu (located drivers rear c pillar behind panel). remove weather strip for door and metal clips and should give you enough room to see the connector.
inspect white red wire for battery voltage with key on.
if no voltage present this is where my issue was found which sounds like alot of you guys are dealing with.
under the DRIVERS side carpet just before the seat (you will have to remove the seat , or in my case lean it back, to examine. if the bolts are fairly healthy then a 10 mm 6 point socket will work) the harness runs down the floor and takes a very sharp bend between bpillar and front floor panel before the seat. everything clipped in and taped as it was at the factory. pull the tape back slightly enough to find the white wire with red trace (believe 18gauge/ thin wire). once found moderatily pull the wire away from the drivers door wide right where that bend is and likely will find the wire corroded and broken. almost as if the insulation cracked over time and allowed the moisture to get in. fix the wire (solder and heat shrink) and retape with cloth tape if possible. test either at tcu or via code scan. or just try and start it.
i only made this account to try and help you guys with what i found because its obviously a manufacturing defect with how hard that bend is. good luck guys
Old Apr 9, 2025 | 05:38 AM
AVLDefender's Avatar
Thank you! That was super kind of you to make an account to share your solution!
Jānis Dravnieks
LR4
Jan 25, 2026 11:10 AM
jdbayer
Dec 24, 2022 12:44 AM
Doug Mitchell
Range Rover L322 (3rd Gen)
Jul 31, 2018 11:52 AM
VolleyVixen
LR2
Jun 21, 2011 11:00 AM
westminster04
May 13, 2009 09:55 PM
