Installing After market caneras
Old Dec 25, 2023 | 06:20 PM
avem7's Avatar
5th Gear
Default Installing After market caneras
Hi guys,
My Disco 4 (LR4) did not came with the surround camera system, i want to install a front camera for off-road and connect it to the factory system,
does anybody knows a way to install a camera to the factory screen?
Old Dec 31, 2023 | 06:01 AM
guy's Avatar
guy
The video input is already in place. You will need management software like SDD to enable the port. Whether a LR or a Jag, there are so many threads on this topic.
Old Jan 8, 2024 | 08:27 AM
keninnc's Avatar
It may be more difficult than you think.
With the Gap tool you will be able to change the CCF settings to turn on cameras in the front.
However the wiring harnesses are different.
Example: When I got my LR4 it was from a salvage auction, small front end wreck. Engine fine but bumper was gone. My LR4 came with front cameras. I purchased a replacement used bumper with no cameras. (bought this version since it was much less expensive and I did not care about loosing front cameras). The new bumper arrived but its wiring harness did not connect to the car's wiring harness. I had to get a wiring harness from a bumper with cameras to use with my used replacement bumper but no cameras are installed.
You may find a wiring harness with the cameras but this wiring harness may not plug into the LR4 since it did not have cameras from the factory. Sometimes Land Rover uses the same wiring harness throughout the car regardless or options but this may be a time due to cost it was cheaper for them to use a different harness if no cameras would be installed.
Old Jan 11, 2024 | 10:17 PM
avem7's Avatar
5th Gear
Thank you guys.
i ended up replacing the head unit altogether and installing a 360 camera system for the LR4. It connects with the new system.
i found that the original cameras are about $200 a piece plus $350 for the module. Then i had to hunt down the wire harness and connectors and find somebody that will get it all programmed. It was more work than wat is worth.
rihov
LR4
Aug 5, 2022 02:36 AM
BD_LR4
LR4
24
Mar 19, 2021 09:57 AM
parthea
LR2
Apr 13, 2019 12:03 PM
James C Everington
LR4
Feb 17, 2018 08:24 PM
avraja
LR4
Apr 19, 2013 12:48 PM
