Jacking points and jack stand placement front/rear
Old Nov 24, 2022 | 05:49 PM
Luke87GT's Avatar
Default Jacking points and jack stand placement front/rear
Hi all,
Does anyone have a diagram that shows the appropriate jacking points and recommended jack stand location for a Land Rover LR4?
Thank you.
Old Nov 24, 2022 | 06:01 PM
DakotaTravler's Avatar
Same as LR3. See attached.
File Type: pdf
File Type: pdf
Old Nov 25, 2022 | 02:01 PM
Luke87GT's Avatar
Excellent thank you!
One more thing, is there anything else I should do besides….
a.) set the parking brake
b.) jack up the car
c.) place on jack stands
(like I do with every other car)?
Old Nov 26, 2022 | 02:18 PM
jlglr4's Avatar
Disable the air suspension. I generally just pull the fuse.
Old Nov 26, 2022 | 07:41 PM
Luke87GT's Avatar
hmmm, where are the fuses located and which is the appropriate fuse for the EAS?
Old Nov 26, 2022 | 07:51 PM
jlglr4's Avatar
Engine junction box. I don’t recall the fuse number - you can probably google it. There also is a fuse legend on the fuse box cover that should help.
I think some people just leave a door open as the suspension isn’t supposed to adjust unless all the doors are closed. Haven’t tried it myself.
A Faceless Man
Apr 13, 2024 12:38 PM
Pangea123
Aug 25, 2023 04:00 PM
WYRover
Sep 2, 2016 06:52 PM
BritCars
LR4
Mar 7, 2016 09:12 AM
4x4 Brad
Feb 20, 2016 08:37 AM
